D
dextrous
Are halfway through first fix for my new kitchen.
They are installing 6mm cable to power a dual oven (4.8kw max) and a ceramic hob (6.7kw max) in the following formation.
Now, although I've heard of diversity, will 6mm really be enough? Or would you suggest at least a 10mm run from the CU to the isolator.
The boys who are putting it in are partially trained and quite experienced, and they get an niceic part P colleague of theirs who does some work for them now to test it and sign it off.
Please don't tell me off (BAS!), it's just that I was under the impression that 6mm would take a max load of 9.5kW, and that if all appliances went on, there would be 11.5kW drawn.
- dextrous
- 1
