At what point of this topic has the function of this light(s) been suggested
They are very good indeed for highlighting particular items or features, or spot lighting small areas. That's what they are actually designed to do
I repeat, unless there are small works of art or architectural features on the floor, what valid purpose would recessed 2" diameter downlights in the ceiling have?downlights into lath and plaster ceilings?
Mankind has, on any level, survived and prospered through a bleedin' miracle of chance!Mankind has, on a macro level, survived and prospered through advancements, not retrogressions.
And even if you don't care about the environment, and are so barmy that you don't accept the problems of man-induced climate change, and can afford the bills, how can you not feel in every fibre of your body that it is just wrong to install something less efficient and less fit for purpose than what it replaces?
And the only reason you can do that is because you are using lights with a beam pattern designed specifically to not light up rooms!
Halogen downlights are so 1980's.
And I want to drive a Ferrari with Claudia Schiffer naked in the passenger seat.customer wants GU10 downlights,
FFS.as im guessing that all standard loft insulation is flamable.
To work with electricity you need a logical mind.
And your logic tells you that every loft in this country has been deliberately covered with a layer of flammable material.![]()
