Yes they will b in parallel just in two parallel spurs if u like from the switched side of the live one going off with 7 lights on the other with just one, just wondered if having the Severn on one parallel circuit and one on the other made any difference both feed from the same switch wire just that a live and neutral go on two ways would b easier to show on a diagram, any way think I av found a way to just wire all 8 in parallel from the junction box ( switch live and neutral ) in one daisy chain thanks for ur help.
Just one other thing that I have found when lifting the floor boards that I have two cables running tight between a joist and two very hot central heating pipes looks like they have used the notch in the joist for the pipes to cram a couple of cables in, must av been done since the house was built do u think I should re route these one I can pull back the other I will have to junction box?
