- Joined
- 6 Nov 2008
- Messages
- 830
- Reaction score
- 16
- Country
its it acceptable to fit a gutter downpipe into an aco drain?
As long as the Aco is connected to something that will drain rainwater.its it acceptable to fit a gutter downpipe into an aco drain?
The groundAs long as the Aco is connected to something that will drain rainwater.
The amount of Acos I have seen cunningly draining into the square root of feckall, is astonishing. Sometimes the 'ground' needs to be defined Woods.The ground![]()
If it gets through planning at the end of the new drive, then that's all that matters.The amount of Acos I have seen cunningly draining into the square root of feckall, is astonishing. Sometimes the 'ground' needs to be defined Woods.
theres a new block driveway going in along my street at the moment.The amount of Acos I have seen cunningly draining into the square root of feckall, is astonishing. Sometimes the 'ground' needs to be defined Woods.
as long as it is a surface water drainYeah it goes into a drain
But a S/W drain not a soakaway ? Like er- mine does, but we're only 100 yds from a river Whole estate has separate S/Was long as it is a surface water drain![]()
The drain going to a soakaway is a surface water drainBut a S/W drain not a soakaway ?
