I recollect reading something in the forum regarding all downstairs sockets being RCD protected. I understand the logic as to why this is an issue but is it a regulation or a recommendation ?
BotchItYourself said:Thanks Adam.
I've seen individual face plates with built-in RCDs. Can these be used on particular sockets to satisfy regulations ?
Why do you not want them RCD protected, or only some of them?BotchItYourself said:Thanks again. Looks like I need to put a bit more thought into my layout.
ebee said:I RCD all sockets.
It`s the only way to be sure,
How often do people do the most unexpected thing?
Always expect them to because they often do.
Adam_151 said:It is not a regulation to have rcd on kitchen sockets, but it is a very good idea IMHO, it is the only room where there is quite a risk of contact between portable appliances and water.
I'd personnaly go the separate circuit route, the ring goes on 32A breaker on RCD side, and a separate circuit, (a 2.5mm² radial, 16A radial) goes on the non rcd side and has sockets for the fridge, freezer and an FCU for the CH. Or this could be two separate radials, one for freezer, one for boiler.
