- Joined
- 29 Sep 2016
- Messages
- 13
- Reaction score
- 0
- Country
Hey all, we bought a 2 bed Victorian terrace almost a year ago and last night the electric suddenly cut out.
We were in the kitchen cooking so had the lights on and whatever else is plugged in/on standby around the house at the time (internet, sky box, fridge freezer, boiler etc). So hardly any load at the time it tripped (btw, the oven and hob are gas and not even connected to electric)
I flicked the mains trip switch and it immediately tripped again. I then removed each fuse (very old fuse box it seems) one by one and narrowed the problem down to the one labelled “Dining room”.
We’d already discovered a few months ago that “Dining room” actually means the entire downstairs – so front room, dining room and kitchen (a total of 8 double sockets). That’s not right is it?
We then unplugged and turned off all sockets downstairs and tried the mains circuit breaker again but it still trips.
Possible Cause 1: a few months back we had a problem with rats under the suspended floor. No idea how they are getting in, pest control suggested they are most likely coming in from either side (terrace house) as no signs of entry on our property. (The neighbours smoke and we can tell this inside our place, so there must be gaps under the floors somewhere!) We put down poison and definitely killed a few and haven’t heard anything since. When poking around under the floorboards we did spot a few gnawed cables but nothing too bad, mostly just in the outer insulation but in a couple of spots there is a mm or 2 of exposed copper in one of the inner wires. In the time we’ve been hearing things under the floors the gnawing of cables doesn’t seem to have gotten any worse – although this is only in the spots we can easily check. So how likely is that a rat has chewed through something and caused something to short out?
Possible Cause 2: We recently fitted a new light in the bathroom. It was an easy job just unscrewing the 3 wires from the old unit and screwing into the new unit (triple checking the wires were correct and all wiring was inside the sealed box within the light unit). It all worked fine so that’s great, I think. The bathroom lights are on the same circuit as all the downstairs lights which is a separate circuit to the faulty sockets circuit. Is it still possible that my DIY light replacement could be the cause of the trip even though it’s on a separate circuit? I’ve already tried pulling the fuse on the downstairs light circuit and reconnecting the fuse for the faulty sockets but it still trips.
I should mention that the morning we fitted the light we went out all day, came home in the evening and noticed the power was out (can’t work out if it was already out when we walked in, or it tripped when we started turning things on – only indicator was the fridge was still very cold – I have a thermometer in there, so can’t have been out for long). On this occasion I flicked the trip switch and it all came back on fine and has been working for the past 4 days now.
So despite the known issue of the rats gnawing cables (it’s entirely possible they are back despite us not hearing a peep from them), I think it’s too big of a coincidence that the problems started after installing the new light fitting. What do you guys think? Is it worth me removing the new bathroom light and seeing if the other circuit still trips?
Thanks for reading
Thanks for reading
