- Joined
- 11 Jun 2016
- Messages
- 391
- Reaction score
- 18
- Country
Gully trap is clear.OP,
Well done for your continuing investigation & finding the damp CWI & rubble that I referred to in post#8.
If you remove block down to FFL level then it would be clear if there now is a DPC at that level or does the DPM go under th blockwork?
You need to remove as much rubble as possible, and to remove all the reachable CWI - you could open the wall up further to the right? Wall openings should be a few feet apart for structural safety.
The render looks fine but definitely observe during rain - or when the exterior is being hose pipe sprayed.
Despite the render looking fine moisture is still maybe penetrating the wall? I think moisture is rising in the cavity rubble & CWI.
Has the gully trap been cleaned out?
Must admit i was concerned about taking anymore blocks out, thinking it might weaken the wall too much.
Will get on it again today. Didn't check the DPC/DPM DOH.
Will do that later
