Hi all,
When we put down the DPM and poured the slab the DPM around the doors ended up being pulled tight across the internal leaf of the door threshold, I think because we made sure the DPM was quite flat on top of the sand.
I assume the only way to solve this is to cut it and patch it up around the door thresholds?
Not sure how it would usually work because of the corners on the two bricks either side of the threshold - hard to find info about this.
In hindsight it the DPM in this area usually kind of bunched up so it would not be pulled tight?
