Hi all,
I am working on a kitchen and have started clearing it out. It has always had awful damp.
You can see the end of the kitchen, whoever lived here has been a fan of the foam...
View media item 91300
After stripping it all out I can see someone has been injecting the wall with a chemical DPC assuming this to be rising damp. However, it is clear that...
1) The outside level is about 250mm higher than the finished floor level
2) When the floor slab was laid the damp proof membrane under it hasn't been tied into the party wall or the outside wall.
You can see the membrane here...
View media item 91301
What remedial measure should I take? Yes, I need to clear outside and get this lower than the internal floor level - but what next?
Should I break up the slab, get rid of everything and start again? Is it possible to tie a new dpm into the wall without rebuilding all the walls i.e. do a section at a time?
Any advice most welcome.
Thanks.
Thanks.
