    Dismiss Notice
Drafty upstairs suspended wooden floor semi-detached house
Discussion in 'Building' started by myk3, 7 Jan 2014.
  1. myk3
    myk3
    30 Jul 2013
    20
    Thanks Received:
    Hertfordshire
    Country:
    Hi all, I have a 1930s semi detached house and while doing a number of things to the house with the floor boards up in all upstairs bedrooms there is a draft between the suspended floor upstairs/down stairs ceiling. There is a bay window at the front of the house which has a small roof which I believe is where the draft is coming in.
    FYI the house is solid brick and has no cavity/inner leaf. Also the external brick work is rendered with NO cracks.
    Firstly is this normal and by design to provide ventilation to the timbers?
    Secondly I would like to pull the carpet up in each room at the external wall use a small amount of insulation held in place with a sheet of wood/plasterboard to the exact width and height of each section which in theory will block out air/draft from any possible gap.
    Thanks,
    Mike
  2. kbdiy
    kbdiy
    8 Jan 2013
    1,549
    Thanks Received:
    243
    Surrey
    Country:
    I would just stuff some insulation (rockwool or similar) in between the joists where they meet the external wall. My guess is you a probably right about the draught coming from the bay.
  3. Sponsored Links
  4. myk3
    myk3
    30 Jul 2013
    20
    Thanks Received:
    Hertfordshire
    Country:
    thanks, i assume the timbers will be ok with the lack of ventilation?
  5. myk3
    myk3
    30 Jul 2013
    20
    Thanks Received:
    Hertfordshire
    Country:
    Hi there, I have pulled up the floor boards close to the external wall on one bedroom and sealed any gaps I could find where air could be coming in through the brick work.
    Can I use celotex board cut to the size of each joist to act as a second seal within the floor.
    My only worry is that there will be zero ventilation in this small section where the joist go into the wall.
    As this is a first floor and not the ground does this matter, I'm a little concerned about ventilation and possibly rotting of the joists if I do this?
    Please advise,
    Mike
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
