Drain cock on mains inlet.
do you reckon i can just drain the entire system from one of these drain offs on the rad tails? (provided i can get a bit of pipe to fit over the outlet)
the downstairs trvs are all busted so im struggling to isolate and drain a rad before being able drain off the rest of the system from a valve
Right, upstairs rads all drained down and water flow stopped.
Problem....all but one of the 7 downstairs rads are not draining..... when i open the bleed valve on any of the 6 remaining downstairs rads, water is squirting out rater than air being sucked in......can anyone advise on how i can drain the downstairs rads?
(All bleed valves upstairs are currently open)
