Drain cock dilema
11 Feb 2009
London
Draining down a combi heating system.
I can only find drain cocks that you connect a hose to, I am aware there are some with a Hozelock fitting.
Either way - you need to have a hose pipe trailing across floors (and in this instance - down stairs) to a drain.
Would it not be better to install a gate or ball valve - and fit a run of copper pipe to a drain.
Only downside is if someone were to poke around, turn say a ball valve and accidentally drain the heating system.
What is the diference between a Type A and Type B cock.
Type A has a gland on the spindle so doesn't leak like type B
And how many customers do you think would pay for that?
And what do you do when you've got several drops to rads?
Type A have an o ring around the spindle and often an o ring behind the knurled ring (if not use PTFE). When you drain down the water doesn't p1ss around the threads and soak the floor.
Type B are cheap and nasty with no seals.
And how many customers do you think would pay for that? point taken, guess it depends where the pipe has to run to.
Type B are cheap and nasty with no seals. Thanks for the tip
I have one of those; it’s a valve between the lowest point in the CH circuit and a bath overflow pipe, so you can drain the CH and it comes out just above ground level next to a path.
BUT - I had lived here for five years before I discovered it. I had even fitted my own drain valve (with hose connection) by that point. I was getting a new carpet in the spare bedroom and decided to investigate a squeaky floorboard first. I lifted the carpet and underlay and there was a large black X painted on the floor where the squeak came from. I undid a few screws and there it was.
