Freezing pipes not an option as feed coming out of the tiles floor. So ...
I have a complicated set up where the kitchen zone is controlled with an actuator. There is a second actuator for another zone. The rest of downstairs is with underfloor heating. Upstairs has a standard radiator set up.
I am trying to work out how to drain down the system of just this kitchen zone (if possible) - the zone has a shut off just before the actuator (the left hand one on photo) and also what I am assuming is the return just below (shut off without handle).
I see no pressure gauge on the JK manifold so assume both the central heating upstairs and UF are controlled by same expansion / feed to top up afterwards and check pressure.
Anyway, hope some one can help and sorry if this info isn’t enough ... wasn’t sure what else to provide for context ...
