Drain nightmare!
15 Feb 2010
Leeds
What do you do about drainage pipes that are in the 750mm footings i have dug?
I know that any pipe below that can be built over with bridges to support the concreate above .
:confused: :confused:
Sorry to be blunt but, first of all
Draw a diagram or even two, ideally showing existing and planned.
Secondly, try explaining again, but skip the anecdotes (e.g. but then i dig the footings towards to house and i hit the toilet drain pipe again!!! )and concentrate on the essentials.
Thirdly, pay attention to your spelling, punctuation and abbreviations.
Finally, what is your question, or what do you want to know?
Then we might have an understanding of your problem and be in a position to advise.
Some drawings (not the best but you might get the idea)
Hmm, now you've completely re-written your original post some important detail is missing.
Is the exisitng connection from your soil stack to the drain run a simple 45° junction?
Is there an IC to the right of that junction?
The main run appears to be little problem, simply lintel over it, or is there more information now missing?
The existing kitchen drain, ask BCO if you can simply concrete it in, 'cos it'll become redundant, (except it may be lintelled over). That's what my BCO allowed in a similar situation.
The soil stack, you may need to insert an IC, if there's not one existing in that area, and re-reoute it, so it comes out more at right-angle to the house and joins at that IC.
By working from the insertion of the IC and then back towards the soil stack, there will be minimal disruption of service to the soil stack.
I took from your reply that the first post was too bad for you to understand, so i have editted to the basic question, to which you asked for.
Yes, the angles on the first diagram are how the pipes enter the main drain, the point they enter the drain are on the diagram too.
Whats an IC?
I understand the main drain can have a bridge over it, i have stated that in the second diagram.
My plan was to cut off the kitchen drain at the point just before it enters the main drain, then cap it off. Then the section that returns to the hopper on the outside if the kitchen window will no longer be used so i assumed it could be destroyed and footing put in its place.
Again i dont know what a IC is?
You tell him mate. After all RedHerring is only giving you his time and free advice. You could always contact an architect at 250 notes per hour. :rolleyes:
Already got an architect and he doesnt charge that hourly rate, feel sorry for you if you pay that amount!!!
I also help people on this forum (as i do on many other forums) for free and give my time, what valid point does that have here.
There is nothing in my post showing disrespect for redherring.
Well it reads that way to me. What does your architect say about it all then (being as he's cheap)?
There is a big difference between cheap and £250 per hour.
I feel you have read my comments wrong, if redherring feels the same way then i will rewrite it.
Ive not contacted him, as i assumed it would be more of a building issue than an architects.
It's just the way it reads, mate. No please or thank you's. Nothing to suggest you appreciate his reply to you. Maybe it's just me but that's how I read it.
@ Joe, Blimey, I thought hell would be freezing over before I gave you a thanks! :eek: ;)
@ bigpkr, IC= Inspection Chamber
I would have thought your architect would have included an IC, or even two.
Edit: I've just realised, looking at your diagrams, depending on how close your other footing is to the main drain run, you might have to go lower with that footing. Footing bottom should be lower than drain run within certain distance. I can't remember off-hand what the criteria are. Maybe others with more experience might advise.
You might also need permission from your local sewerage company.
I was unaware that the drain would be there, on my drainage search it shows the main drain the street, the i knew it went down the side of the house (found it while digging).
I also knew the kitchen outlet would be in the way but i assumed it would be the only one, so i could just cut it back to the outside of the new extension and bring back to the surface.
He has put a 500mm man hole but that is for the surface water drain i have to lay.
Should i just dig out all the footings to spec (750mm down 600mm wide)then get BC out and do as he says. Ive hit clay at 200mm so the 750mm down should be enough for BC.
My advice for the quickest and best way to resolve the problems is to arrange a site meeting with your architect and BCO to discuss and resolve the issues. There's possibly more then you've realised.
Take notes at that meeting 'cos you probably won't remember it all.
List the items for discussion and list the resolutions.
BCO won't mind and it won't cost you anymore.
Architect should have built contingency in fees.
Ive just seen your edit re permission. I thought this but a "mate" told me that yorkshire water has no changed the rules. If the drain is within you property then all repair costs are down to the house owner.
Rules changed about a month ago.
Yes, dig out all footings, ensure drain runs are exposed sufficiently to determine falls and directions, then arrange meeting.
