Hello again, just to say that I have a rad that has a very very slow drip from the drainage pipe. As I'm not a plumber I am not sure what its really called but I have seen plumbers use this with a bit of hose to drain the rad before removal. Hence I call it the drainage pipe!
It drips really slowly when rads are working, does not drip when cold. Have tightened a little, as far as I dare go and no change. Without wishing to run up a big bill I wonder if I could bung the whole with a small bespoke cork or similar? Highly unlikely I will ever need to use the pipe and if I leave a cork end exposed it could be taken out again with pliers or whatever (if really needed). Any advise on this action please?
thanks
Stephen
thanks
Stephen
