- Joined
- 6 Feb 2012
- Messages
- 110
- Reaction score
- 9
- Country
We have three radiators on our CH system which remain cold. They all have TRVs, two of the radiators heat up when the valves are tapped. The third doesn't heat up at all. The system is heated by a Worcester Bosch Greenstar 30 CDI.
Before we replace the valves we want to put Fernox 3 in to see if that solves the problem.
We opened all the bleed valves and drained down the system. The F&E tank was very slow to drain, and probably didn't drain fully. Also a couple of (working) radiators stayed filled with water once everything else had drained.
1. Why might the radiators not be draining properly and how do we get them to drain properly?
2. The water coming out of the system is very clean. So is there any point in putting Fernox 3 in - given the number of double radiators we have we would be putting 1.5 litres in so not cheap. Though when we bled some of the radiatorss blacker water came out so might there be local corrosion stopping the radiators working that Fernox would clear out?
Thanks in advance
Thanks in advance
