Hi all
I went to my stepson's today to fit a new towel rail on the first floor.
I wanted to drain down the system so I turned the valiant combi off and put my garden hose on the drain down point nearest the front door.
I turned the valve so much that it came out. No water came out though.
I then went to the next nearest drain down point- same thing.
I then checked the boiler. There is something that looks like a micro drain off point on the 22mm heating pipes but opening one of them only releases about a pint of water.
I went back to the first drain off valve. They are the type with the top that you can remove (type A in screwfix?). I gave it a couple of gentle whacks. Then I tried to stick a thin screw driver up the spout. I then rather gingerly tried to prize the stuck plate with the washer on it after removing the spindle. Still nothing.
What is the cleanest/easiest way to drain down the system?
I am guessing that I could drain the biggest radiator down stairs. Let it refill. Drain it. That will be enough to let me work on the pipes upstairs but he will still be left with no practical drain down point.
Would heating one of the drain off valves melt the rubber washer enough to use the screw driver up the spout to work? I am happy to replace the washers in the valves but would rather not have to desolder the valves and re-solder new ones if I can get away with buy new valves and fitting new "guts" in to the existing valves.
Thanks.
Thanks.
