- Joined
- 4 Nov 2004
- Messages
- 8
- Reaction score
- 0
- Country
I think my electrician has screwed a screw into one of my heating pipes leading to/from a radiator in one of my bedrooms. I obviously need to look at the problem before I call a plumber but he has screwed the floorboards down, if I unscrew and its one of these srews thats the cuplrit I'm just going to make the problem worse aren't I?
If I turn water off at mains and drain the system does it also drain the heating system enabling me to investigate? I have a combi boiler if that helps.
Lastly (if you're still reading!) is if its a small hole can i fix it or does the pipe need replacing?
Sam
Sam
