Draining horizontal pipes
17 Jul 2014
London
As part of my increasing jobs, I need to cut some pipes to below floor level and cap them. Capping no problem, going the blowtorch way (fire, we like fire)
I've stopped the mains, emptied the systems before, that's fine, it's just dealing with physical below floor horizontal pipework I'm not sure how to catch the unknown quantity of water (22mm pipe coming from bathroom to en suite by the looks of it).
I can't get a bucket under there, got roughly 10cm space to play with
Compression or pushfit and a bath towel on a bin liner.
Or solder if you want a difficult life.
Don’t try to solder a cap without an open end. You’ll fail.
Thanks Jeff, this pipe could be 3m in length, that's going to be a lot of water potentially coming through the downstairs ceiling(!)
Be quick. Not as much as you think!
Use a pipe slice not a hacksaw.
The bath towel is not to dry yourself off!
On the upright of these pipes (originally for a shower unit), the previous plumber decided to use a pushfit right on an angle without a collet, just a touch made it fly off, had to work fast to get a compression stop end on that and do it properly(!) great fun!
Never used a hacksaw on pipework, always a pipe slice, great little things, almost therapeutic! The bath towel today was definitely for me, and the dog, he was being nosey just at the wrong moment :D
