- Joined
- 29 Oct 2009
- Messages
- 426
- Reaction score
- 31
- Country
hello guys,
I need to remove a radiator by next weekend so i can knock the wall it is aatached too.
I have found the pipes that come to the radiator before they go into the concrete floor.
Is there anyway I can cap the pipes off without having to drain the system down. or should I drain it. I have found what I assume to be the draining point. How much water should I expect to come out? should I run the pump for the system whilst draining it out?
I should also add that the boiler is sheduled for replacement at the end of the month. Should of been prior but the plumber had to knock me back 2 weeks
So would that doing this work cause any issues for the iminent works. Eg would the plumber like to see the old system running prior to replacing.
Thanks in advance
Rob
Thanks in advance
Rob
