Hi
I have a problem with my heating system which i am sure is fairly common in older houses.
The drain point for the heating system is on the kitchen rad, the problem i have is most of the pipes run under the concrete floor so there is a lot of water lower than the drain point, the last time i re-routed a pipe it was a nightmare dealing with the remaining water in the system.
I am thinking of getting a small pump to suck out the water?
What do you use and is there an easy way of doing this?
