Drayton DIgistat 3+ programming/use 22083
4 Jan 2009
Herefordshire
Fitted one of these.
Its a 7 Day or (5-2 Day) model.
I want Fridays to be different, so I have changed Fridays in the program, however it is treating Friday just like any other day in the week.
Anyone know how I resolve this ?
Are these any good ?!
If you have the programmer set to 5/2 mode, i.e Monday to Friday using one block of settings and Sat/Sun using a second block, you can't just change Friday by itself. You will have to use it in 7 day mode and programme each day individually.
It's explained in the User Manual which can be found here - see How to change the pre-set time/temperature program to my own selection.
I have read that bit.
How does it know if its working in 5/2 or 7 day mode ?
The last one you have adjusted ?
The drayton timer LP722 makes it easy.
got it sorted thank you.
Also calibrated the sensor (2°C out) which is making it work much more sensibly ! and have a warm house again.
