Hello everybody,
I would be extremely grateful if anyone could help me with this problem.
I have searched several forums on the subject but I couldn't find the answer. If there is one available, please accept my apologies and kindly point me to the right direction.
I have recently switched a SwitchMaster 905 Hot Water-Central Heating programmer with a Drayton LP241, because it is indicated by dozens of websites as compatible, though trivial re-wiring is needed.
According to the documentation accompanying the new timer, it just comes down to switching the terminal 1 and 4, for H/W off and C/H on.
I have done it and checked the work done many times, and everything appears to be in the correct position.
However, although the timer for the H/W is working fine, the one for the C/H isn't and the central heating always stays on, even when I put it in the "OFF" position.
The only way to switch the C/H off is to switch off the mains (the switch with the 3 Amp fuse).
I have a Y-plan system, and I have read that in this case the wire for C/H off is not needed and, indeed, it wasn't available on the SwitchMaster 905.
I would like to understand what's going on and any help would be greatly appreciated.
Best regards
Best regards
