I have purchased a Drayton LP241 programmer to replace a Potterton Myson EP2000. The information sheet supplied with the programmer tells me that I should be able to do this quite easily and gives information on how to wire it. Unfortunately, it has not been that simple. The EP2000 has five connections excluding the live and neutral and terminal 2 on the back plate had no wires going into it so I assure that I could just use just the 4 terminals that are on the back plate of the LP241. There was also a wire that was connecting the live to terminal 5 on the EP2000, so I assumed that this could be put into terminal 4 on the LP241. The problem I have it that if I wire it as stated on the Drayton comparison sheet the hot water control on the LP241 operates the central heating and the central heating control does nothing, also, on the the Drayton comparison table it states (link L-5 and N-N) could any one tell me what that means? I have been very careful in following the wiring diagram and I am very sure that I do not have any wires mixed up. Can anyone help.
Many thanks
Many thanks
