Hi guys.
First post so treat me gently.
I have a really weird problem with a Drayton MA1 mid-position valve and I can't find any reference to this specific problem.
The system is a conventional gravity-fed system with gas condensing boiler, Lifestyle LP522 programmer, Drayton RTS1 room-stat, Honeywell tank-stat, Drayton MA1 MPV and ACL Lifestyle Wiring Centre.
The system has been working perfectly for 14 years until yesterday when the domestic hot water was cold.
I checked the MPV and it was still in the Heating position from the previous evening's central heating demand.
I removed the head unit to check the valve shaft for freedom and the actuator still stayed in the Heating position even though the DHW was set to Off! The shaft of the valve is very free and I can turn it with my fingers.
I turned off the power to the system and immediately the actuator returned to the relaxed, Water, position under spring pressure.
With the head unit removed from the valve body, turning on the system and demanding Heating causes the actuator to move to the H position. Turning down the room stat satisfies the demand and the system shuts down the boiler and the pump but the actuator remains in the H position. Cycling the demand fires the boiler and pump but satisfying the demand with the room-stat has no effect on the actuator which stubbornly remains in H.
However, turning off the system power causes the actuator to return immediately to the W, relaxed, position under spring pressure. Turn on the system power and everything works as it should, until the Heating-only demand is satisfied when the actuator remains in H.
At this point, demanding Hot Water causes the actuator to move to the W position and if the demand for Heating is still there, the actuator moves to the mid-position. (This is counter-intuitive to the problem of no hot water in the morning as when I test the system the actuator moves with hot-water demand even though it had not done so yesterday morning!)
So, it seems as though everything is working normally until there is a demand for Heating only, when, once it is satisfied, the actuator remains in H. This is repeatable!
I have checked the power to the MPV and there is no voltage on the White MPV wire with heating satisfied.
I am at my wits end as the 'logic' just doesn't seem logical. It seems as though it is 'stuck' electrically rather than physically as turning off system power causes the actuator to 'relax' under spring pressure and yet there is no voltage energising it when it is 'stuck' with the system power on!
As always, any inputs greatly appreciated.
Regards, Brian
Regards, Brian
