Drayton TRV4
12 Dec 2007
Lincolnshire
Do you need to do anything with these valve heads when fitting them on the return side of the radiator like you would with Danfoss TRV'S. I notice numbering on the black plastic valve head is this for balancing.
Rob
14 Aug 2006
London
You dont use TRVs for balancing. Just stick the head on and it will control room temp. Simples :D
19 Feb 2009
You can put them now on flow or return as they are bi-directional.
The numbers are temp settings.
8 Jan 2005
Bath
You balance the system with the other valve, be it on the flow or return.
18 Oct 2007
Kent
No, they can go on either end without any changes. The head can be either hosrizontal or vertical.
If you are talking about the numbers surrounding the pin, then these are for balancing, but you need a special spanner to do this.
It's all explained in TRV Commissioning Guide.
28 Jan 2005
London
You can stick them on either side of the rad, but in general it works best if all the trv's are on the flow and the rads balanced with a lockshield on the return.
