Drayton Wiser install with Worcester Bosch CDI30
25 Jun 2019
Looking for advice to confirm how to wire up a new Drayton Wiser 1 channel smart thermostat to a Worcester Bosch CDI30. This will replaces an existing Drayton LP20RF dual channel digistat and wireless thermostat (easily removed).
As there’s no existing wall plate I need to wire this in.
Great to get confirmation of my understanding on the wiring for this (shown in my crudely drawn diagram)
Basically am I right in doing the following
From wall plate To boiler
N To N
L To L
Common (1) To Ls (Live switch)
Heating on (3) To Lr (live return)
Earth To Earth
I know I need to remove the bridge too.
Images of the boiler connectors and wall plate also included as might be helpful
Thanks for the help!
Steve
1AF35AAD-E74D-4D94-A9DB-B7C5399F12BC.jpeg F21BE9C7-BA2F-4869-9CA7-DB884D358113.png A2268599-AF1C-428C-86D1-1B0CE0699236.jpeg
Your drawing of the wiring connections as you show them would work OK. However, as Ls and Ns provide a 'Live Supply' and 'Neutral Supply' specifically for remote controls, I would connect it like this. It's easier than trying to get two wires in the boiler N & L terminals.
You should be careful with some combi boilers though. If yours is of a design where you have to open up a room sealed part of the boiler to access the wiring terminals, this is not a DIY job and should only be done by an RGI who can carry out the appropriate safety checks afterwards to make sure it is properly sealed up again afterwards. Unfortunately I don't know if your model of boiler falls into this category or not.
Thanks Stem. That makes a lot more sense to link the Live and Common (and a much smarter diagram to mine).
Thankfully no sealed parts to access in the boiler. The terminals are easy to access, just under a standard cover plate.
Appreciate the help!
Would this wiring diagram work for a Greensted 30SI with Drayton wiser 1, and do you have to remove anything as mine is already on a wireless thermastat
If you post details of your existing wireless stat and the wires connected to it, someone will be able to advise how to swap it for a Drayton Wiser.
