Drayton Zone Actuator ZA5
7 Dec 2012
Sussex
Hi
Thanks to these forums I have been able to 'solve' my lack of heating mystery however I still have a 1 query.
My house has been fitted with 3 of the above zone actuators along with the Drayton wireless thermostats. My house has 3 areas of heating - the bathroom rads the downstairs zone and the upstairs zone. The bathroom rads are always on except for my bathroom which has never worked despite changing a 'stuck' TRV. Anyway I can live with that - just. My problem was that the upstairs heating never really worked properly after the first year of fitting. Come the winter of the second year I found that I had to operate the digital receiver manually to have heating and this year (year 3 of fitting) nothing worked. The thermostat was requesting heat and the receiver was getting the message and both seemed to be working fine but the radiators were cold. Finally found the culprit was the actuator which was permanently on the A mode whilst the others were on B and working fine. pressed the black button on the top and it slowly went to B and voila! warm radiators!
My question now is - and from these forums I understand that the black switch should move freely - indeed click from A to B and back. This one seemed to be sluggish as if coated in grease and dust - I understand that I can lubricate it - would this be with a simple spray of WD40 or is it more complicated and intricated than that?
The A - B on the side of the actuator is not a lever it's just a indicator of the position of the valve, The lever that is for manually opening the valve is the one on the end of the actuator.
If your valve is sticking it's more likley the actual brass valve that's more likley stiff/seizing.
If you look on the opposite side of the A-B there will be a button you can push in that releases the actuator from the brass valve.
Once off check if the brass spindle turns freely.
Hi Seco services and thanks for the suggestion. Both thermostats and receivers were working properly and it was as you said the little spindles in the actuator that were totally bunged up with gunk and not working. I cleaned them on both actuators and have had the central heating working a treat for nearly 2 weeks now. Thank you!
