Drill bit to use for 3 core 0.75 power cable
26 Jun 2014
Bournemouth
Hello
I need to drill through my outside wall , into the house , to fit an outside light , my power cable is 3 core flex cable 3183y 0.75mm , i have a drill bit which is obviously very long , which i have used before to drill from in to out , but this drill bit would be far to big a hole for this cable to come through
Has anyone got any advice on what drill bit size i can use to ensure a nice finish ?
7 Feb 2008
Northumberland
If you are going to use 20mm conduit, then you'll need a 22mm bit or larger for clearance.
You are maybe thinking about cable glands, but these are for use in boxes usually.....I just bung the hole up with silicone.
John :)
26 Jun 2014
Bournemouth
Hi John
what size conduit do i need if my drill bit is 10mm ?
If my drill bit is 10mm is this OK for my power cable?
I was thinking of the cable gland ? that fits in the hole with a circle on the end which tidys up the hole made from inside?
Outside , i dont mind sealing with silicone too much!
sorry for all questions! i want it to look tidy as my wife is a stickler!
7 Feb 2008
Northumberland
Owain is bang on the money with the wall grommet!
For conduit, you'll need a bigger drill than the 10mm one, but you will be able to pass the cable through by itself, and then use the wall grommet.
Stick the grommet in with silicone if you need to.
John :)
26 Jun 2014
Bournemouth
cheers
will do that , should look a little neater in any event and would rather not use a bigger drill bit than absolutley necessary
