drilling hard thin plastic bumper
15 Nov 2005
South
Cook Islands
I have a car where the bumper has a 90degree lip turned over at the edge, which fixes to a similar lip on the wheel arch surround. they were previously attached with a plastic fastener that broke off, breaking the hole, in a bump.
I wantto drill a couple of 6mm holes in the two lips so I can bolt them together
what sort of drill and technique will go through them with minimal risk of tearing or jamming?
I’d use a 4mm HSS jobber drill bit, followed by a 6 when you are done......pressing down and turning a scribe will give you the equivalent of a centre punch mark to start.
John
done it now thanks
when I got it off I found a broken locating dowel, and drilled through that, put a bolt through it to pull them together
