- Joined
- 4 Jun 2016
- Messages
- 47
- Reaction score
- 1
- Country
Hi forumites,
I need to attach a 70mm by 200mm 1 meter lengths of timber underneath a large 200mm by 200mm 5 meter steel i-beam in order to make up for the difference between the sliding door height and the structural opening height.
My engineer suggested I can drill as many holes as I need on the bottom flange in order to bolt the timbers with m10 bolts without affecting structural integrity (as long as they are within a specific line not too close to the web or the tip).
My question is: is there any specific kind of bolt I should use? Also, without a magnetic drill or one of those guns, is patience and good quality hss drill bits the way to go or does anyone here have any hints?
Thanks in advance!
Thanks in advance!
