Hi. I'm trying to use one of these:
To cut a 25mm hole in a piece of tile (off the wall) that's only about 45-50mm wide. So there is not much tile on either side of the hole, and after three attempts the tile has cracked in two each time the drill comes close to finishing the hole. I'm going as slowly as I can, it takes about 10 minutes to cut through. Water cooled, in a hand drill (not a press, don't have one) and using minimum pressure.
Any ideas? Or is it just too small a piece of tile that's always going to fail? I'm using standard cheap square white tiles and there's a pipe I need to get around that's very close to a corner. Unfortunately the cracks are not neat enough to just line the tile back up on the wall, it's still quite visible.
Does anyone know the OD of cheap plastic pipe collars? If they'd extend across the whole width of the tile piece then they might cover the crack for me.
