I recently moved into a new flat and got my very small kitchen refitted. Unfortunately the new hob extractor had to be removed and replaced. After the old one was removed the rawlplug / screw had to be removed as it was too loose, there has also been previous screw holes close by. In removing the old rawlplugs plaster has come loose and there is now a 50p size hole about 3/4in deep with screwholes deeper still.
The fixings for the new extractor means a screw will have to go here.
Whats the best filler to use? I've got plaster or should I get deep fill polyfilla? or something else?
Once its dry will it be able to cope with the load?
