S semi-acoustic Joined 7 Jun 2006 Messages 197 Reaction score 3 Location London Country 10 Jul 2007 #1 Can I drill through fibreglass and if so what drill do I use? any info would be truly appreciated. Thanks Steve
T techwondo Joined 14 Jun 2007 Messages 73 Reaction score 0 Location Yorkshire Country 10 Jul 2007 #2 From what ive heard, you can drill through fibleglass but you need to use a blunt drill bit (oddly enough) so you dont spoil the gel coat.
B breezer 10 Jul 2007 #3 bit of sticky tape and a sharp metal bit, i have used hole cutters and flatbits, but you only get one go
B Belle427 Joined 16 Jan 2006 Messages 3,229 Reaction score 362 Location Newport, S Wales. Country 10 Jul 2007 #4 if you start the drill in reverse when you attempt the hole it will stop any grabbing of the bit causing cracks,cone cutters can also help as they are less agressive
B Belle427 Joined 16 Jan 2006 Messages 3,229 Reaction score 362 Location Newport, S Wales. Country 10 Jul 2007 #6 you dont have to leave on reverse,just until you have start to cut the surface
R Ron Gamma Joined 6 Apr 2006 Messages 161 Reaction score 0 Location London Country 12 Jul 2007 #7 if you can get to the back of the panel drill a pilot hole from behind. Then open this up from the front with a standard "metal" drill bit. seal the edges with gelcoat or primer to stop the moisture getting into the fibres.
