Hi guys,
Well, phase 1 is complete (run dedicated cold feed from cold water cistern to airing cupboard).
Now you can all laugh at the numerous plumbing noob mistakes I have no doubt made (1st time plumbing DIYer, all I've done before is plumb a dish washer in and that was with help from dad!).
Seriously, thanks for all your responses. I hate the part where you switch the water back on. I was convinced it was going to leak at least somewhere, but it didn't or hasn't yet!
I have yet to lag the pipes as you can see. The stuff I got from Screwfix is very thick, which I suppose is a good thing from an insulation point of view. However the way the pipe is routed in the attic, there's not much room left for it. Any alternative lagging techniques for where space is tight?
The connections are Cupro-fit, which I found *ok*, though the hardest part was working out how to disconnect the buggers. The tool came with no instructions and there are various adaptors etc. The valve at the end is a full bore ball valve, seems very robust and maybe slightly overkill.
All sorted though, here are some pics.
If the flange arrives tomorrow, I'll be performing phase 2, or maybe I should call it 'phase poo' since that's what my pants will be full of about the time I drill into the copper.
That's a Salamander CT50+ sitting on its rubber feet, some concrete, and a gardener's keeling pad.
