R
richard7761
Hi. I need to get some "long series" hss twist drills (capable of cutting through thin metal sheet). About 150mm long-ish.
Basically, the drill needs to cut through a 100mm wide beam (and on it's way also thru two sections of thin metal sheet).
Okay: If I use a 6mm drill for a 6mm coach bolt, will I be able to pass the bolt through the wood with reasonable ease?
Or will I need a 6.5mm drill bit?
Thanks.
Thanks.
