hello every one,
i have not installed a Drimaster 2000 15W ,before, just a request if you could help. It requires 1amp fuse only.
Shall i have to run a new Circuit from CCU or use the existing Lighting Circuit.
Can i use 5amp Fused Spur for it as well or the the unit has got its own Fuse inside should be enough.
or the best way to connect that if you could explain please.
Any replies will be highly appreciated. Thanks.
