dripping tap
5 Jan 2008
Hi there, I've got an annoying drip from the tap in the kitchen. It's one of those taps with a single spout which comes up about a foot then bends to point downwards and can be swung from side to side. There is a tap handle on each side, cold on right, hot on left, each about a three-inch long lever which turns towards you from vertical (off) to horizontal (full on).
I might not be describing this well. From looking on the web I'm thinking "quarter-turn" comes into this. Do you think I'm right about the quarter-turn i.e. it's not a case of a rubber (or whatever) washer I don't think?
There is no inline on/off valve before the tap so I'll have to turn the water off, which is from the roadside since there's no mains turn-off tap in the house either. Because I'd most likely have to order the valve online it would be great to do that before starting work on this. Otherwise I'd have to leave the water off if I was unable to refit the old valve after taking it out to identify it.
So is there more than one type of quarter-turn valve please?
(In normal pre-virus times I could just have pulled the valve then nipped for a replacement while leaving the water off. In normal times I'd probably just get a new tap cos the old one's a bit scruffy, then get a plumber of my acquaintance to fit that plus a couple of inline valves and if possible a mains tap for future use. But there we are.)
Thanks for advice.
Regards, Terry.
Thanks denso13. The tap was there before we moved in but I think there's some documents about the kitchen lying about somewhere. I'll have a look but could take a while to find :-)
Nah can't find document re kitchen tap, just bathroom ones.
This link : https://www.notjusttaps.co.uk/identify-your-tap-or-shower-cartridge-and-replace-it.html
tells you what measurements to take so looks like I'll just have to turn water off, pull the valve, measure it, pray that I can get it back in e.g that it hasn't disintegrated or anything so I can get the water back on, and order the right valve online. Fingers crossed.
BTW I make it a rule never to start a job like this on a Friday, Saturday or Sunday in case I need to shout for a plumber if it all goes pear-shaped, so it'll be early next week!
- Terry.
Get yourself some citric acid from the chemist shop. Turn the water off, remove both tap cartridges and soak them in a solution of citric acid and water, until all of the limescale has been dissolved, halfway through the soaking, swap the off position to on. Often it is just limescale which prevent them from sealing fully.
