Hello,
I'm installing some 50mm insulation board as part of some renovations that. Had looked at the laminated plasterboard, but need space for socket backboxes/cables etc. without compromising the insulation and vapour barrier.
I'll need to dry-line this, and also hang a 450x1400mm radiator on the wall.
Not sure of the radiator weight - I think it's probably > 50kg (bog standard Stelrad).
Am I best off using 2x4 timber and essentially building a stud wall, or will smaller battens do?
Or is there a better way of fixing the radiator brackets straight through to the stone, bearing in mind the sheer forces on long bolts?
Cheers,
Andy
Cheers,
Andy
