Hi, I hope you can help... I have recently had a single skin porch built from Celcon Solar 300mm blocks. The specs require Gyproc Thermaline Super 50mm insulation backed plasterboard on the inside. The guy who was doing the external rendering yesterday suggested I PVA the wall prior to applying the insulated plasterboard by dot & dab. This I did & I applied a little pressure once the boards were on by using a couple of extendable props secured on the opposite newly installed plasterboard wall, if that makes sense...
after 3 hours I removed the props & immediately noticed that the board on one wall was not secure & it didn't take much persuasion for it to come off. The dabs were stuck to the wall but not to the board.
I have spoken to Gyproc who, after much consultation, advised me that I went wrong by PVA'ing the blocks?! Apparently the dry wall adhesive has in it a product which deals with the suction already. As it is not possible to remove the PVA they state the only way I can secure the boards now is to batten the wall & fix it to the battens. Problem is by doing so It will reduce the size of the porch further & we don't have that luxury. New baby has come along & the porch was built to take the pushchair & all the associated clutter.
Has anyone come across this type of problem & found a solution? Any helpful suggestions would be really appreciated.
Many thanks
Many thanks
