I have a DM Digital sprite 2 installed on a job with 16 cameras, a lot of these camera pictures keep getting green screens but will dissapear for a while after the unit is reset. I have spoken to tech support and they have said it can be 2 things, first it could be the codec board which is on the way out OR it could be that one or more of the cameras is causing this problem as the V p-p is not at 1 volt.
Firstly has anyone experienced this before?
Second, how exactly do you test for 1v p-p output from the camera? And if you do test it and it falls out with this then is there anyway to change this or does it mean the camera should be bereplaced?
