In the middle of an ongoing ensuite upgrade. I am fitting a Dual Fuel towel warmer. I am aware that you need to have supplemenarty bonding to bring all metal work taps/pipes etc & incoming circuits to the same potential.
Two Questions:
1. The towel warmer has a heater element and central heating. Can I connect the CPC from the FCU (for the element) to the supplemenatry bonding loop negating the need to bond the towel warmer pipes as well? Or do I need to bond the flow and return from the towel warmer in addition? I wanted to avoid earthing clamps on my nice stainless steel warmer.
2. Same room has a shaver socket connected to the light circuit (fairly standard I think) Do I need to bond the CPC from both the light and shaver socket, and/or should I fit an RCBO to the current upstairs light circuit which isn't protected by RCD at the moment?
Two Questions:
