DualHeat 12u
  • Thread starter Thread starter DP
  • Start date Start date
DP
10 Dec 2003
Glasgow
This is a 12 Kw cylinder that is heated by off peak electricity. Cylinder provides mains pressure hot water and heats radiators when heating is required. This cylinder is obsolete as are the parts
Does anyone know of a similar cylinder or setup that could replace the 12U
Loads. Look for Thermal Store. The 12kw immersion heater is a bit rare, 2 x 4kw seems the norm nowadays. Mains pressure DHW- either use a big coil in the tank or an external plate heat exchanger and a pump (to circulate hot primary water through the hex).
