    Dismiss Notice
What is the impact of removing cold water tanks from the loft?
Discussion in 'Plumbing and Central Heating' started by nmg196, 11 Jan 2021.
  1. nmg196
    nmg196
    11 Jan 2004
    53
    Thanks Received:
    Country:
    I'm considering a loft conversion in my house as as part of adding an extension. However right in the dead centre of the most useful space, are the two tanks for cold water and central heating.
    If I have an open vented setup, what is the least I can do to convert to mains pressure and remove the large cold tank at the least? I guess the small tank for the heating could be reclocated so it's not in the way, but I'm guessing the existing cylinder for the hot water is not designed for mains pressure and would have to be replaced? If so, what would replace it? Can I get a mains pressure cylinder and put it where the current cylinder is and can I keep my existing boiler if I keep the smaller tank?
    Thanks!
  2. Sponsored Links
  3. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,739
    Thanks Received:
    1,086
    Country:
    Yes Yes and Yes.
    Providing you have sufficient cold water supply
  4. nmg196
    nmg196
    11 Jan 2004
    53
    Thanks Received:
    Country:
    What would the pressure need to be? I have a pressure gauge I bought when there was a temporary loss of pressure many years ago.
  5. endecotp
    endecotp
    2 Dec 2013
    3,949
    Thanks Received:
    507
    Country:
    You need to measure the flow rate, not the pressure.
  6. footprints
    footprints
    21 Sep 2011
    4,466
    Thanks Received:
    957
    Country:
    Easiest solution would be to consider changing to a Combi boiler, no tank in the loft mains pressure to your shower and you gain the space where the cylinder was.
  7. nmg196
    nmg196
    11 Jan 2004
    53
    Thanks Received:
    Country:
    It's a 4 bed house with 3 showers though, so I wasn't sure a combi would be "gutsy" enough for that?
  8. JohnD
    JohnD
    15 Nov 2005
    73,415
    Thanks Received:
    4,226
    Crossgates, Europe
    Country:
    Cook Islands
    it's not the pressure, it's the flow that is likely to be your problem.
    edit
    too slow!
    20 litres per minute will be fine
    12 lpm adequate for a shower but meagre to fill a bath.
    In an old house you may need to replace the supply pipe and valves, and some of the internal pipes, with larger ones.
    this is not as difficult as you think.
  9. footprints
    footprints
    21 Sep 2011
    4,466
    Thanks Received:
    957
    Country:
    Yes you are right it would struggle.
  10. Sponsored Links
  11. Gasguru
    Gasguru
    9 Sep 2005
    12,237
    Thanks Received:
    3,234
    Sussex
    Country:
    Screw in a pressure gauge nearest the incoming water main.
    Measure the pressure with no flow at various times of the day (you might be on a shared main and the pressure could vary).
    Ensure the boundary and internal stopcocks are fully open.
    Then open a cold tap and record the pressure at different flowrates...say 10 litres/min, 15, 20 etc.
    Use a measuring jug and stopwatch...most Weir gauges are junk and inaccurate.
    Once done you can tell whether there are any problems and what's the best way forward.
    With that size house and bathrooms a combi (including storage type) is not a good idea.
    • Thanks Thanks x 1
  12. nmg196
    nmg196
    11 Jan 2004
    53
    Thanks Received:
    Country:
    Its from 1996 so not too old. It seems to all be 22mm or 28mm everywhere I can see pipework, except for one run to a single hot tap.
  13. nmg196
    nmg196
    11 Jan 2004
    53
    Thanks Received:
    Country:
    Can a high pressure cylinder fit in an airing cupboard where the old tank was or are they a lot larger?
  14. footprints
    footprints
    21 Sep 2011
    4,466
    Thanks Received:
    957
    Country:
    They are a lot taller and the tundish discharge will need to run outside by gravity.
  15. Madrab
    Madrab
    4 Oct 2012
    8,036
    Thanks Received:
    2,274
    East Renfrewshire
    Country:
    If you have three showers then in this case the pressure is just as important as the flow. You can easily have 20L/min @1.5bar but the minute you go to 2 or even 3 showers that drops to .75bar then it's a waste of time and your dancing about the shower trying to catch the water.
    For your application I would advise, if you want to be able to use all three showers at the same time, that you want around 3 bar dynamic pressure with an absolute min of 20L/Min on a 22mm supply to and from the cylinder.
    The size of the cylinder will be dictated by the amount of water you will need. For 3 showers then at least a 180L cylinder, you can shop about and compare sizes
  16. nmg196
    nmg196
    11 Jan 2004
    53
    Thanks Received:
    Country:
    Thanks Madrab. There are only two of us in the house at the moment but I don't want to fit something which doesn't eventually scale when our baby arrives in a few months. That said I think the chances of all three people needing to shower at the exact same time is pretty negliable. I would plan for two showers max. I will measure the pressure and flow rates when I get some time.
  17. Gasguru
    Gasguru
    9 Sep 2005
    12,237
    Thanks Received:
    3,234
    Sussex
    Country:
    Baby girl or boy...better get a whacking great cylinder if it's a girl. Been called back to installs where a teenage daughter has drained the cylinder every shower. :rolleyes:
Loading...
Share This Page
