Hi all, I've just replaced a cistern, not an easy feet for me but seemed to go ok.
I swapped a Dudley for a Dudley Vantage. No leaks but when I flush the water fills really slowly, like it would probably take 10 minutes to fill or longer.
But if I knock the assembly on the left (the bits with the long plastic shoot that the water runs down) the water shoots out at an acceptable speed. And once its flowing, if I flush before it shuts off, it fills correctly again and again, but once it shuts off, the next time you flush it runs very slowly, a trickle but you can then nudge the assembly and it will start to flow again.
Any ideas as to what i touch/move to fix it.
