Dulux BW emulsion - not white?
18 Oct 2006
Buckinghamshire
Just painted the hall in Dulux BW emulsion, Skirtings, doors etc painted in Leyland Acrylic white gloss (Screwfix) to avoid the yellowing problem.
The Dulux Emulsion looks slightly cream, even checked the tin to mae sure I had picked up white.
Have they changed the emulsion colour so their gloss doesn't look so yellow or is it a sign that the gloss is really white?
Can't say I've noticed Dulux emulsions being off white but I usually only use their trade versions.
Acrylic glosses do tend to appear very white so it could be just the contrast between the two, as you suggest.
Other than that, white emulsion can appear to be slightly cream if it is painted directly over smoke/nicotine stained walls. Could that be a possibility?
Does it look whiter in the tin than on the walls? If so, it may be caused by some form of contamination/bleed from the surface it has been applied to.
What colour did you paint over - some colours can show through the white if you haven't applied enough coats to hide them.
Hmm, perhaps it is the whiteness of the acrylic gloss that is making it appear that way then. I don't use water based glosses regularly, and haven't often used them alongside white emulsion, so perhaps some of the other guys can advise you if your problem is anything out of the ordinary.
Other than that, perhaps the tin of emulsion is faulty. :?
Perhaps you could try painting a scrap bit of wood or plasterboard, then carry it around and compare it with other paintwork.
