am building a conservatory with about 6 bricks above dps. below dpc is 5 bricks, 2 of which will be above ground level.
now, i have brought some weephole vents, the plastic vertical ones that go between the bricks.. questio is, where below the dpc do i put them? obviously can only be in the top 2 layers of the wall above ground level, but which should it be?
also, should i fill the cavity with a sandwich (i believe its called) of cement and taper it towards the exterior wall so water can get out? if so, the weepholes will no doubt need to match that level.
tahnks
tahnks
