If the supply pipe is metal and the stopcock is metal then surely the stopcock would need bonding since its introducing a potential to touchable metalwork within the equipotential zone.ColJack said:it it's plastic your side, don't..
even if the supply side is copper / lead etc..
davy_owen_88 said:Main bonding should occur at a point closest to where the service enters the house and on the consumer side of any meter/stop-cock. If this is under the hall floorboards you shouldn't bond there as the clamp should be accessible for inspection and testing. If the pipe emerges from under the floor in the kitchen, and it is bonded there, then you have no problems.
Lectrician said:People always say running an earth cable will be "near impossible".
I bet if you wanted a shower, hot tub, cooker you would find a route?!?
Even if ALL pipes where plastic, I still would run a main eq bond to the origin in any case - future, and the fact that plumbers often change their minds....
If the incomming pipe is copper/lead etc, I would FORCE the plumber to offer us a length of copper to attach to - period.
Paul Barker said:It should be obvious to you to 10mm meb on that short stub of copper to the met and if what you say iscorrect about the rest of thepipe being copper obviously bond across that lime fighter which a/ is a waste ofspace and b/ is probably plastic.
how your question has become so complexed baffles me.
