[come in Consumer Unit
Hi All,
Would be grateful for any help please.
There is a switch between my meter and consumer unit. This is earthed locally.
The consumer unit is also earthed (if everything is sound - the cable looks to have been there for 20+ years). The cable run is about 4 metres before it is connected to an earth point outside the house.
Unfortunately this cable passes through the wooden door frame of my front door. I am having a new door installed and need to move this earth cable. I do not want to drill through the new PVC frame to replace the existing connection.
Three questions really:
1) does there need to be a second earth connection to the system? ie: from the consumer unit itself?
2) if there does need to be a second connection, can I secure the second one (the one I need to move) to the same place as the first one?
3) if 2) is not possible, can I leave the second earth connection "disconnected" for a couple of days until I can get an electrician out to do a proper job?
Many thanks for any replies,
Cheers,
Jon
Hi All,
Cheers,
Jon
