Hi all,
First of all sorry for these questions but i've been searching and reading posts for 2 hours and not really got myself a confident answer.
In my house i have installed a Combi Boiler and 5 radiators as it only originally had a hot water boiler upstairs.
I have basically done all the pipework and installation ready for a Gas Man/Electrician to obviously do the gassing/electrical work and pass the whole thing...
Currently as you can hopefully see from the picture, there is a 6mm earth cable running from the CU (top of the picture), down the back of the board and it loops onto the earth strap on the gas pipe then onto a cold water pipe near where the cold water comes into my house.
I now need to earth the Hot Water and the Central Heating so;
How is it best to do this and should i really even be attempting it? (bearing in mind it will all be checked appropriately before testing anyway)
In the picture (Circled in red) there is what appears to be a spare earth connector... Can i run a 6mm earth cable from this spare point to the hot water pipe and loop it onto the central heating pipes in a similar way. If so do i need to link it across the flow and the return pipes or just one of them and should it be done at a certain point in the system?
Sorry it's so long but i like to try and explain everything fully.
Any suggestions are much appreciated as always..
Cheers
Cheers
